Slow?
Have a problem with the website? Maybe you can find the answer here.
Slow?
Postby Av8r3400 » Fri Dec 09, 2011 6:37 pm
Has the site been running a little slowly over the past couple of days or is it just me?
Av8r3400
Kitfox IV - 1050, 912UL - Flyer
Kitfox IV - 1200, 912UL - Project
Than live trying not to die.
-Leonard Perry
Av8r3400
Re: Slow?
Postby mountainmatt » Fri Dec 09, 2011 6:59 pm
It's hung up a few times, but that seems pretty normal around here.
180A
Backcountry flying videos: FlyingPoochProd
mountainmatt
mountainmatt's Photo gallery
Re: Slow?
Postby ZPilot » Fri Dec 09, 2011 7:45 pm
I am having the same problems. It is taking each BCP page about 20 seconds to load regardless of content. This started about 3 days ago or so.
ZPilot
Re: Slow?
Postby Brian - Steve's Aircraft » Fri Dec 09, 2011 8:23 pm
Been slow on the computer, but real fast on the phone using Tapatalk....
Brian.
Pavement scares me..........
Dad's SPOT page
Brian - Steve's Aircraft's Photo gallery
Re: Slow?
Postby 58Skylane » Fri Dec 09, 2011 9:01 pm
Brian - Steve's Aircraft wrote:Been slow on the computer, but real fast on the phone using Tapatalk....
Brian.
It's been pretty good on both the computer and my Droid. I don't use Tapatalk. Just the free version. I did notice when you hit the "Submit" button, that's a little slow. I think that's what causes a lot of double post's from some (and I almost done the same). I think they hit "Submit" the first time and nothing happens for a few or more seconds, then they hit the "Submit" button again creating the double post.
Re: Slow?
Postby kevbert » Fri Dec 09, 2011 9:25 pm
58Skylane wrote:I think that's what causes a lot of double post's from some (and I almost done the same). I think they hit "Submit" the first time and nothing happens for a few or more seconds, then they hit the "Submit" button again creating the double post.
Maybe they're just screwing with you, Pat!
kevbert
kevbert's Photo gallery
Re: Slow?
Postby 58Skylane » Fri Dec 09, 2011 9:28 pm
Yeah........ whatever dude!!! [-X [-X Must be the cold wind up there?? :D :lol:
Re: Slow?
Postby kevbert » Fri Dec 09, 2011 9:44 pm
58Skylane wrote:Yeah........ whatever dude!!! [-X [-X Must be the cold wind up there?? :D :lol:
That's a pretty good guess! =D>
I cracked a tooth a couple of days ago, and the cold air is excruciatingly painful. I'm getting a crown on it in a couple of days. But, in the meantime, I went down to the bar this evening for medicinal purposes, and now I'm cracking myself up [pun intended]. :D
kevbert
Re: Slow?
Postby 58Skylane » Fri Dec 09, 2011 9:50 pm
21 in Emmett right now. But feels like 10 Image
Re: Slow?
Postby Av8r3400 » Sun Dec 11, 2011 8:22 am
It can't be just me, now. :(
Last evening I couldn't even get the site on my phone. Very slow response and Firefox often times out waiting for the site to load. Skiplane.org and other forums I frequent are normal speed, so I don't think it's on my end...
Av8r3400
-Leonard Perry
Av8r3400
Re: Slow?
Postby 58Skylane » Sun Dec 11, 2011 9:34 am
Av8r3400 wrote:It can't be just me, now. :(
Mine was fine last night and this morning. I didn't try my Droid though.
Re: Slow?
Postby Av8r3400 » Sun Jan 15, 2012 5:43 pm
Over 30 second load time for the last week or more now, again. Things sped up quite a bit until the last week again.
Tell me if this is normal and I will quit bringing up this topic...
Av8r3400
-Leonard Perry
Av8r3400
Slow?
Postby svanarts » Sun Jan 15, 2012 8:07 pm
I have this issue at work but not at home. I would waste far more time on this site if it didn't load so slow at work. Seems like bcp just doesn't like some IP ranges.
svanarts
Re: Slow?
Postby kevbert » Sun Jan 15, 2012 8:27 pm
30 seconds!? That's not normal. Maybe your freakish mutant super powers are kicking in, making your brain so fast that each second seems like a minute.
If all sites are slow, then check to see if your computer is doing anything unusual. Look to see if the hard drive light is extremely busy, if your DSL modem has unusual activity on the lights, etc. If you see a problem, try looking at things like the amount of free hard drive space, the amount of free memory, the number of other programs running in the background, the number of users on your local network and what they're doing on the internet, sources of radio interference for wireless devices, times of day when the idiots down the block are using up all the DSL bandwidth watching kittens on youtube, any evidence that you might have a virus, etc.
If BCP is the only site that is slow, try pinging backcountrypilot.org. (If you aren't familiar with ping, you open a command window and type "ping backcountrypilot.org" without the quotes and hit enter).
Here's my results. Notice my time is 51.5 ms, which is pretty fast.
Code: Select all
kevbert@amd64:~$ ping backcountrypilot.org
PING backcountrypilot.org (69.163.157.112) 56(84) bytes of data.
64 bytes from backcountrypilot.org (69.163.157.112): icmp_seq=1 ttl=52 time=51.5 ms
If ping is slow, run a traceroute to find the offending node.
Code: Select all
kevbert@amd64:~$ traceroute backcountrypilot.org
traceroute to backcountrypilot.org (69.163.157.112), 30 hops max, 60 byte packets
 1  home.gateway (192.168.1.254)  1.950 ms  1.932 ms  1.937 ms
 2  66-232-74-1.ctcweb.net (66.232.74.1)  18.493 ms  18.607 ms  18.599 ms
 3  ip-66-232-90-25.syringanetworks.net (66.232.90.25)  19.312 ms  20.174 ms  21.607 ms
 4  te4-3.ccr01.slc01.atlas.cogentco.com (154.54.40.89)  171.441 ms  171.456 ms  171.954 ms
 5  te4-2.ccr01.smf01.atlas.cogentco.com (154.54.1.101)  75.165 ms te9-8.ccr01.smf01.atlas.cogentco.com (154.54.47.173)  75.787 ms te8-8.ccr01.smf01.atlas.cogentco.com (154.54.47.177)  76.332 ms
 6  te0-0-0-5.ccr21.sfo01.atlas.cogentco.com (154.54.25.201)  53.967 ms te0-2-0-0.ccr21.sfo01.atlas.cogentco.com (154.54.42.65)  37.262 ms te0-0-0-1.ccr22.sfo01.atlas.cogentco.com (154.54.80.65)  38.903 ms
 7  te0-1-0-2.ccr21.lax01.atlas.cogentco.com (154.54.3.137)  53.203 ms te0-0-0-1.ccr21.lax01.atlas.cogentco.com (154.54.3.193)  51.893 ms  52.580 ms
 8  te7-1.mag01.lax01.atlas.cogentco.com (154.54.28.142)  54.345 ms  55.503 ms  76.903 ms
 9  38.122.20.218 (38.122.20.218)  58.498 ms  49.795 ms  50.758 ms
10  * * *
11  backcountrypilot.org (69.163.157.112)  52.980 ms  50.153 ms  51.145 ms
Note that on Microsoft operating systems, the traceroute command is conveniently renamed to tracert. :roll:
If pinging BCP returns a fast time, but the site is slow, it might be the web server is overloaded (but I'm not seeing it), or it might be an ad on the page whose server is slow (ads come from a different site, they aren't stored on the BCP server) . You can try pinging each of the ad servers on the page, but it's easier to just turn off the ads. I use the firefox browser with the "Adblock Plus" ad blocking plugin installed, and that makes all of my browsing much faster, even when the ad servers are working fine. However, I occasionally use someone else's computer, and I'm surprised how often a page load pauses while it's waiting for some stupid ad site.
If that doesn't help, you'll need to provide more information about the problem.
kevbert
Re: Slow?
Postby 58Skylane » Sun Jan 15, 2012 9:28 pm
WTF Kev?? That's some pretty high tech info there!!!
:D :D :D
Re: Slow?
Postby 180Marty » Sun Jan 15, 2012 9:53 pm
My ping is 83 to 101. Why is Supercub.org mostly in the 20's or a little more? More people looking over there?
Re: Slow?
Postby kevbert » Sun Jan 15, 2012 10:32 pm
Ok, just for 58skylane, :D
I've been looking at the site, trying to find for testing purposes 1) a page that is text only, and 2) a page that doesn't have ads. But, it would seem that our cost-conscious leader has put ads on EVERYTHING. Sigh...
So, here's the first test, a non-existant page on BCP. The web server will just return text informing you of the error. This will test how quickly a packet or two will go through the network and get processed by the web server. This removes most of the other variables like ads, databases, etc.
http://www.backcountrypilot.org/fakepage.html
Here's the second test, a half mb image. This will test web server response and network throughput, and remove most other variables.
http://www.backcountrypilot.org/gallery/albums/userpics/10005/2-12-2011_%2830%29.jpg
Edit: if you click on this more than once, it will probably cache it on your computer and not fetch it from the internet on subsequent tries. So, if the image displays TOO fast, refresh the browser (press F5 or CTRL-R or whatever) to make it display again, this time it should load from the server.
If these tests are fast, and the site is slow, then it's probably the web server, database, or ad servers that are overloaded.
If the image test is slow, it's probably the web server or the network.
If the text/error page is slow, it's very likely the web server.
kevbert
Re: Slow?
Postby kevbert » Sun Jan 15, 2012 10:35 pm
180Marty wrote:My ping is 83 to 101. Why is Supercub.org mostly in the 20's or a little more? More people looking over there?
You might be closer to the SC website, or it might run on faster hardware, or a combination of both.
kevbert
Re: Slow?
Postby Emory Bored » Sun Jan 15, 2012 11:08 pm
The site is working fine for me, but any archived content, like say a google Stinson search, stops cold. Times out.
Emory Bored
Re: Slow?
Postby 58Skylane » Mon Jan 16, 2012 8:21 am
Just jacking with you :D :D
But, this site works flawless with my laptop and the computer at my work. The only thing I don't see on my work computer is some pictures. They have a lot of stuff and webpages blocked.
Return to Technical Issues and System Updates
