Backcountry Pilot • Anyone have a close up picture of a 206 fork on a 182?
18 postsPage 1 of 1
I'm wondering if I need to put this wedge piece in between the block and the fork? I havent seen the wedge piece on any other 206 forks. Anyone? Thanks.
-Worthy
ington6 offline
Aircraft: C185
C90 Cub
Re: Anyone have a close up picture of a 206 fork on a 182?
You can look at my gallery under "my 182". Not a 206 fork but a Landis....let me know if that works for you
I will do better this afternoon. A photo with a bit moor air in the strut.
You need the wedge, I don't remember which way it goes but it shouldn't be too hard to figure out. Might look in the parts book or service manual.
Edit: The manuals are all here available for download if you need them:
http://www.micro-tools.net/pdf/Cessna/
and a snapshot from parts manual:
qmdv wrote: A photo with a bit moor air in the strut.
Why would you want Moor air in a strut?
Making fun. No crepes for you [-X
tim
tim
See Tim, I'm not the only one F ing with your spelling! :lol: :lol:
Here is my 310 fork on the 182B. The 310 is the same as a 206 accept that the 310 has little mounts for the fender just aft of the axle.
Notice the lower cowl. Anybody else have a patch on a patch
Not sure if I should answer the question about cutting the tube on this thread or your new thread on the same subject. I will gust take a chance here. On the previous 182B that I had, we cut an inch off the tube as per the field approval that we coppied. On this 182B we did not cut the tube. We did not copy a field approval, we did it from scratch.
And as far as the wedge that is on some of the 206's, I have never seen one on a 182.
I've got the one piece, cast 206 Fork (on the floor of my hanger :evil: ) with no mounting block or wedge. I have a 337 from another C175 that used the same fork I have and it doesn't say anything about cutting the strut tube. I really don't want to use a Landis fork because they are 14 lbs and the Cessna one I have is only 7.
If anyone needs the one shown in the above drawing there was a guy in Spanish Fork selling one last year. I could make a call or get his number if anyone needs one.
Jaerl offline
qmdv wrote: I will gust take a chance here.
"gust"?? As in a gust of wind flipping up a girls dress?? :lol:
Tim, did you triple wall your cowl to keep the Frozen Cow Turds from denting it? :D
Jaerl offline
Tim, is that mud on that tire, or cow turd? :lol:
58Skylane wrote:Tim, is that mud on that tire, or cow turd? :lol:
Probably a combo of the two. Thinking of mud flaps to keep it off the underside of the wing.
Haha, yeah that might help. I'll get you some of those chrome naked lady mud flap emblem's some of those truckers put on their mud flaps. :lol:
qmdv, your the first person ive seen to just bolt it up to the existing hole in the strut tube and keep the old scissor linkage. Im in the same predicament. Hook the scissor linkage to the fork and mount the fork on the top hole (2" higher), which requires cutting the excess 2" off the strut tube, or mount it like you did. Just bolting it up to the old hole where my stock fork bolted on the tube. Now im very confused after seeing your picture. I have the option for the HD nose fork on my plane, wondering how they did that package from Cessna. Different strut tube? different linkage?
ington6 offline
Aircraft: C185
C90 Cub
jmorgan offline
1969 182-M
P-Ponk
I used a 310 fork as well but had the mechanic shave off the fender attach points. We did not use the wedge and that causes a problem with the grease zerk on the scissors.
http://www.flickr.com/photos/newps/5039623137/sizes/o/in/set-72157624945420003/
ington6 wrote:qmdv, your the first person ive seen to just bolt it up to the existing hole in the strut tube and keep the old scissor linkage. Im in the same predicament. Hook the scissor linkage to the fork and mount the fork on the top hole (2" higher), which requires cutting the excess 2" off the strut tube, or mount it like you did. Just bolting it up to the old hole where my stock fork bolted on the tube. Now im very confused after seeing your picture. I have the option for the HD nose fork on my plane, wondering how they did that package from Cessna. Different strut tube? different linkage?
Look in the parts book at both set ups (500x5 vs 600x6). Compare part numbers.
18 postsPage 1 of 1
