Backcountry Pilot • NOAA Weather Map w/METAR & TAF
9 postsPage 1 of 1
Re: Weather Maps
Nice find, Pat. I'm going to change your subject to make it more specific.
Re: NOAA Weather Map w/METAR & TAF
Sweet, that's a good one to add to the bookmarks.
Another one from NOAA
Gives a good description to the weather.....in terms that even I can understand.
http://forecast.weather.gov/product.php?site=NWS&issuedby=PQR&product=AFD&format=CI&version=1&glossary=1
Terry offline
On the area forecast text how do you change the location? Or what tab is that page located on the site? It looks like a good resource!
Titus577 offline
I'm not sure, I looked briefly but didn't get anywhere.
This is the URL that I start with (pacific NW).
Click on AFD under forecast discussion.
http://www.wrh.noaa.gov/pqr/forecasts.php
Terry offline
Titus577:
Check your local NWS office. For me, I go to the Sacramento site. Not knowing where in SoCal you are from, I'm guessing you are in the LA/Oxnard office region:
http://www.wrh.noaa.gov/lox/scripts/get ... d&back=yes
Hopefully this link will get you the forecast discussion. If you are in San Diego or Hanford office's region, I can get you a link to those sites too, or just search the area pages for the forecast discussion. See here: This should work for anyone else interested.
http://www.wrh.noaa.gov/wrh/forecastoffice_tab.php
Like Terry I find this discussion to be some of the best info available as to how confident the weather guessers feel about the accuracy and severity of their forecasts.......I usually make sure I look at it in addition to any flight briefing I get. There is good discussion on winds during fair weather flying, as well as many of our areas that are not well covered by TAF's.
Flynengr
flynengr offline
If you go here: http://www.wrh.noaa.gov/ You will get to the main NOAA weather service page.
Click on the map for your area. For example Scaratamato.
And you will go here: http://www.wrh.noaa.gov/sto/
Along the left margin you will see Forecasts. Under there should be a Forecast Discussion choice. I have noticed each region has a different term and format for the discussions. For example the Sacto page calls it AFD Discussions and SEA calls it Frcst Discussion and Text/Graphical are the choices. Graphical is where you can click on the highlighted terms for further explanation.
This and the Aviation Forecast areas are a wealth of weather information. You are paying for it you might as well use it.
TD
TomD offline
Aircraft: Maule M5-235C
AirWx and NOAA both have great weather apps
Sent from my HTC Evo using Tapatalk
Mongo offline
9 postsPage 1 of 1
