Kennon's
engine covers are okay, though the last set of wing
covers I got from them were pure junk. Those things disintegrated in a couple of seasons. Their "high tech, anti UV" material wasn't UV resistant at all. Hopefully, that doesn't apply to their
engine covers.
I prefer a good fitting cover, and my experience with Cessna 170
engine covers is that the makers don't extend them far enough aft to actually cover that gaping hole in the bottom rear of the
engine cowling. The last Kennon cover I saw was like this, by the way, and in fact, every one I've seen is.
I had Cunningham
Covers make an
engine cover for me that was longer, ie: reached further aft for my 170. It
covers the entire lower cowl opening, and holds the heat a LOT better than any other I've seen. Here's a link to Cunningham:
http://www.aviationcovers.com/
I believe Kennon will build a custom cover as well, and probably any of the folks that make these
covers. Generally, they make them when you order, so it's not a big deal to incorporate some changes. Cunningham modified mine with this and a "stovepipe" vent for $25 extra. I considered that a deal. If you plan to heat with combustion heaters, like a Northern Companion or Red Dragon, you need to have a vent panel up in the front of the cover, where heat can flow OUT of the
engine compartment, after its risen up through the compartment. Mine is just a velcro flap at one of the upper cowl inlets, and works great. This works as a stovepipe, and moves hot air THROUGH the cowling and around the
engine. Don't go without it, if you're ever going to use one of these heaters.
Alaska Wing
Covers makes pretty good stuff as well. Here's their site:
http://www.alaskawingcovers.com/
I do like the bungees and tennis balls for fasteners. I find the plastic or metal hooks ugly to deal with when wearing gloves, and stretch one of those babies waaaaaayyyyy out and slip with it, and it'll leave a mark on your face like you can't even believe. Course, I been smacked in the head by a runaway tennis ball as well.....
I really like Cunningham's stuff. I've been boycotting Kennon since my experience with those wing
covers.
But, whatever you do, tell whoever builds the cover to make it a good six inches longer (reaching further aft) than they normally do for a 170. And put in a stove pipe vent.
