1SeventyZ wrote:... You either know exactly how much fuel you have, or you don't. For me, 20 gallons is no less safe than 37 gallons, as long as I'm keeping track. ...
You are soooo wrong! Keeping track only works 99.99 percent of the time, and then there's the exception!
I always use a 1 hour reserve of fuel in the tanks as my personal standard. In spite of that, one day it ran dry when I should have had close to two hours of fuel remaining! I couldn't believe my luck
, but I was in the pattern practicing spot landings when it happened, so it was a non-event. My math was perfect on the amount of fuel I had burned, the problem was that I didn't account for the fuel that leaked instead of getting burned. It turned out that the seal in the fuel selector valve had sprung a leak in flight, draining my tanks.
I then realized the benefit of those transparent tubes that are used for fuel gauges in a lot of experimentals. You can see the actual level of fuel in your tanks.
