hotrod150 wrote:flathorn wrote: This thing belongs to a good friend of mine. No there are no wings. I tried to convince him to put on my Helio Courier H800 wings and to build out the fuselage area at the wing location with stubs 8'6" overall and attach the wings to those stubs to increase the overall wing span. ....
Is there an advantage to more wingspan gained by increasing cabin width (as opposed to wing length)? The cabin portion doesn't "fly" so I wouldn't think so, but I'm definitely not an aeronautical engineer.
And is that airplane gonna have a trailer hitch so it can pull a bass boat?
An airplane fuselage usually does create lift at positive AOAs. It does so much less efficiently than a wing, since a fuselage has an aspect ratio of <1. If you google "Lifting Bodies", you may see some neat NASA research aircraft that used a fuselage only to create lift (warning: I haven't tried this so who knows what other pics you'll get).
I wouldn't consider this an "advantage" in this case though. My thoughts are greater frontal area for more drag, more weight for a bigger fuselage, more wetted area for drag, and stuff like that.
One thing that may be of interest, is that when one sees a "wing area" number, that does include the wing area that is part of the fuselage. So if you have two airplanes with the same wing area, and one has a very wide fuselage, it may have less lifting capability, due to having less real wing. This always kinds bothered me during my classes, but since the fuselage can actually create some measure of lift, it is left in as part of the wing area.
