Wax on Airplane Skis?
Postby Super-Maule » Mon Jan 24, 2011 4:39 pm
Hello Backcountry Pilots,
Is there any advantage in waxing airplane skis? The bottoms on my skis are mirror smooth plastic. Downhill snow skis are not smooth and are slightly groved the length of the ski. Anyway I landed in some real heavy snow yesterday and it was about 40 degrees F. It was real difficult to get up to take-off speed under these conditions. Everywhere else they worked just fine. Any "constructive" advise would be greatly appreciated.
Thanks,
James
Spokane
Super-Maule
Super-Maule's Photo gallery
Re: Wax on Airplane Skis?
Postby patrol guy » Mon Jan 24, 2011 5:59 pm
more hp always helps.
oh wait, you said "constructive", sorry.
patrol guy
patrol guy's Photo gallery
Postby Zzz » Mon Jan 24, 2011 6:10 pm
Warmer snow has always compelled me to wax my [human]skis more than any other condition. It can be extremely draggy.
I usually use Swix yellow, which is formulated for 32 F and greater. I rough up the base a little with a fine brass brush, and drip the wax arlong its length just to get some on there. Then I use a regular cloth iron set very low to smear it around and melt it into the texture. After that dries, I scrape it with a polycarbonate or even chamfered aluminum scraper. Excess wax does nothing.
As to the composition of the bases for aircraft skis, you're right. Downhill skis have a fairly smooth finish, but they have enough texture to retain wax. None of my skis have grooves. It's all the same stuff-- UHMW or HDPE/HMPE. Courierguy told us a story about some ski shop that refused to wax his Datums because of the base material. Well, it's the same stuff! My theory is that most ski shops have a machine that they run the ski through and it does all the work, and Courier guy's shop might have been a lazy stoner unwilling to do it by hand (just a theory, Tom! I've been in too many shops to have any other opinion :))
Biggest issue is that a wax job will not last long, maybe a day or 2 or use. Getting to the bottom surface of that ski is major PITA. :P
Zzz
Amateur
Zzz's Photo gallery
Postby akavidflyer » Mon Jan 24, 2011 6:25 pm
james wrote:Hello Backcountry Pilots,
Thanks,
James
Spokane
wet snow can be a bitch, wet snow with wheel skis and you can be waiting for it to cool off before you get out. I know several people who have had to wait till the next morning when it was colder to get off the snow, even after they tried to pack it down with snow shoes. A tail ski will help you out alot too. Without it, your pushing forwards to get that tail wheel up, but then your really loading you main skis and compounding the problem. I was always the guy that swore he didnt need a tail ski till I actually tried one. Holy shite what a difference it made!!
akavidflyer
akavidflyer's Photo gallery
Postby Super-Maule » Mon Jan 24, 2011 8:32 pm
Thanks Akavidflyer,
Thats good information. I just got to get more experience with the skis too. Its a heck of a lot different on skis than floats. Going to fly to the Elk River, Idaho Airstrip on Friday on skis for some blue berry pancakes.
James
by Zane » Mon Jan 24, 2011 5:10 pm
As to the composition of the bases for aircraft skis, you're right. Downhill skis have a fairly smooth finish, but they have enough texture to retain wax. None of my skis have grooves. It's all the same stuff-- UHMW or HDPE/HMPE. Courierguy told us a story about some ski shop that refused to wax his Datums because of the base material. Well, it's the same stuff! My theory is that most ski shops have a machine that they run the ski through and it does all the work, and Courier guy's shop might have been a lazy stoner unwilling to do it by hand (just a theory, Tom! I've been in too many shops to have any other opinion )
Zane,
That is a good idea about having a ski shop wax the airplane skis. They are not a heck of a lot wider than a snow-board. I'd be curious to see how long wax would last on wheel skis. One problem is that my airplane skis have runners and wear -strips that would have to be removed too.
Thanks,
James
Spokane
Super-Maule
Postby courierguy » Tue Jan 25, 2011 8:26 am
Don't sweat it James, wax won't stick, they are NOT ski bottoms, as in downhill skis. My stoner tuner has been doing it for 20 years, since dropping out of high school :shock: And knows from past experience it is different stuff.
One less thing you have to screw with. Watch out for your first cross wind landing on hard pack, it won't be like you may expect.....no ground looping thing, just a drift to the side while tracking straight, hard to explain, you'll see, but it sure got my attention and I have good skegs.
courierguy
Postby M6RV6 » Tue Jan 25, 2011 8:38 am
James
Glad you got them on and in the snow!
Everyone will say BS but if you are going to be in some wet snow, before you leave lift up the front of those skis and them hold a can of PAM on it's side and spray he'll out of all that you can! Helps on the first takeoff after you put the skis down, I can show you some picture of my M6 sitting on its belly in the warm wet snow!! Only took 7 days to get it offf the Glacier and a broken 185 to do it. Snowed 9' while we were gone! Becarefull and have fun. Make sure you have a bag of garbage sacks,snowshovel ya a grain scoop is the best with a good handle, and a good set of snow shoes, not those little 2' long ones but something you can pack about 1500' of runway. When you get into the deep snow a tail ski is a must.
GT
Keep SMILIN!
GT
Brousard
Wilga
C210
M6RV6
M6RV6's Photo gallery
Postby dirtstrip » Tue Jan 25, 2011 8:44 am
An "around the farm tip" might help this ski sticking thing. When I take a scoop shovel outside to shovel snow the aluminum is warm and the snow melts on and sticks to it. Spray it with Slip Plate, a Case- IH spray on graphite we normally use for helping seed slide down in the planter hoppers , it sure makes a difference. Right on the can for other uses it says it will also make it difficult for ice to stick on metal surfaces so I have also used it to spray on the steel sieves to help keep snow from refreezing and sticking to them. I would check compatibility with the poly ski bottom of course but since the seed hoppers are fiberglass and seed plates are poly these days I would think it would be just fine.
dirtstrip
dirtstrip's Photo gallery
Postby goldfinch » Wed Jan 26, 2011 10:23 am
Wet snow holds you back no matter what you do. Lower temperature is the only way out of some of that stuff. In the spring, an experienced guy will quit using skis before he can use wheels. Snow will still be on the ground so it is hazardous for wheels, and on skis you won't nose over but can't get back out if its too wet and sloushy. Cold snow---to---- dry ground is the longest wait time of the year for the BCP.
wings, cary me over the big rocks
goldfinch
goldfinch's Photo gallery
Postby Zzz » Wed Jan 26, 2011 10:52 am
courierguy wrote:...it is different stuff.
Tom, I don't think it is different. Ptex is just HDPE or UHMW. I think the difference is in how it's surface finished.
From an entry on wikipedia regarding HDPE:
wikipedia...UHMW wrote:The bottom of most modern skis — the surface that contacts the snow — is coated with UHMWPE, treated for compatibility with waxes and with epoxy base material. These treated materials are known as P-tex, Isospeed, or Durasurf.
So perhaps UHMW without this special treatment just won't hold wax, like your shop guy says.
Zzz
Amateur
Zzz's Photo gallery
Postby mtv » Wed Jan 26, 2011 2:14 pm
In my experience, UHMW as used on airplane skis, dog sled runners, etc won't hold wax for very long--about one landing, actually, depending on the conditions.
The Rosti Fernandez retractable skis use UHMW that is prepared like the bottoms on downhill skis, and those skis WILL hold wax for a bit longer, and it really does help on those skis.
But, most skis have a really slick bottom material, and the wax just scrapes off really fast. Besides, have you ever tried waxing a set of skis that's mounted on an airplane?? :roll: Good luck. I tried, but...
Warm snow (as in temps of 40 degrees :shock: ) is ugly stuff. I would NOT land in snow on skis if the prevailing OAT was over about 30 degrees. Now, there may be situations where that will work, as in shallow snow, big wind, etc, etc. But in general, if the temperature is that warm, you ARE going to use a LOT of room to takeoff.
IF you actually take off, that is. I've waited till 3 AM more than once in spring snow conditions, with deep snow.
Ski flying is a major learning program. Just make sure you've got good survival gear with you and you'll be safe camping out, cause sooner or later......you will.
mtv
mtv's Photo gallery
Postby DonC » Wed Jan 26, 2011 3:09 pm
Chip sounds like u have been there done that :( I know I have :roll: Never got stuck over night but came close a few times. Heavy duty leaf bags or visqueen always saved me. Would be a hoot watching these guys try and wax their skies, never heard of that one before. I was just happy when they came up with the white P Tex , or what ever they call it now a days, that made a big difference. Never stop till u got a take off runway beat down or have snowshoes :mrgreen:
goldfinch wrote:Wet snow holds you back no matter what you do. Lower temperature is the only way out of some of that stuff. In the spring, an experienced guy will quit using skis before he can use wheels. Snow will still be on the ground so it is hazardous for wheels, and on skis you won't nose over but can't get back out if its too wet and sloushy. Cold snow---to---- dry ground is the longest wait time of the year for the BCP.
DonC
DonC's Photo gallery
Postby Zzz » Wed Jan 26, 2011 5:56 pm
All I know is that without warm temp formula wax on, I have nearly gone ass-over-teakettle on my skis after skiing into a warm patch (usually dirty snow that gets some sun.) With warm temp wax, not nearly as much drag.
Zzz
Amateur
Zzz's Photo gallery
Postby dlhanst » Wed Jan 26, 2011 8:04 pm
I was talking to Chris from Airglas today about some ski related issue and he brought up this topic about waxing skis. I always thought the bases were different fron downhill skis but he said no, they were very similar and waxing was not a bad idea. He suggested the xc type rub on type if you can raise the skis and a standard iron and hot wax before installing the skis for the season. Also p-tex can repair the large gouges in the bases. News to me! Hey AkTahoe-let's go!
dlhanst
Postby courierguy » Thu Jan 27, 2011 7:45 am
DonC wrote:Chip sounds like u have been there done that :( I know I have :roll: Never got stuck over night but came close a few times. Heavy duty leaf bags or visqueen always saved me. Would be a hoot watching these guys try and wax their skies, never heard of that one before. I was just happy when they came up with the white P Tex , or what ever they call it now a days, that made a big difference. Never stop till u got a take off runway beat down or have snowshoes :mrgreen:
I had one bad experience last spring, where I landed on slush and didn't make my turn around in time before ending up in mud! I thought about it long and hard before retracting the skis and to my surprise I was able to wheel out of what I couldn't move in on the skis. I never even had to get out of the plane. When I got home home I looked at all the mud and decided maybe it was time to go back to the Airstreaks. I've got 9k down to 4k altitude I fly in right near home, so as spring nears the conditions can really vary. I call going up to the ski area behind my place (sounds like a high dollar setup, it ain't, trust me) "checking on the snow for the plane", and it is always fascinating to feel the different snow with the altitude change, instructive too.
courierguy
Postby goldfinch » Thu Jan 27, 2011 8:41 pm
Don:
I'm not very smart, but once was enough for me. I spent three hours trying to stamp out the start of a set of ski tracks in crumbling slushy snow four ft. deep. I never could get up enough speed to get even close to t.o. speed. Finally I just set there and waited for the dark and hoped the cold would be enough. About three hours after dark it was no problem to get airborne.
After that when ever I had to land in the snow with warmer temperatures, I'd make two or three tracks in the snow then land on the tracks, then still expect to have to wait till it got cold.
I think straight skis cause a lot less drag than wheel skis. Like straight floats verses amphibs.
goldfinch
Return to Ski Flying
