PT6 U206F
Re: PT6 U206F
Postby lancef53 » Thu Aug 26, 2010 8:27 pm
Whats with the tailwheel turbine 206 in the gallery? Photoshop? Looks awesome!!
lancef53
lancef53's Photo gallery
Re: PT6 U206F
Postby Skydive206 » Sat Sep 11, 2010 6:48 am
DER has the drawings and it should hold a target 450hp max continous power. Engine mount powder coated, all fuselage reinforcements riveted in place. Large nose gear fork reinstalled and waiting on my 6.00X6 tire and wheel to arrive. Engine will be hung begining of next week. Pictures to follow. I have the next set of fuselage attach fittings ready and second engine mount coming out the the jig.
Skydive206
Skydive206's Photo gallery
Re: PT6 U206F
Postby lowflyin'G3 » Mon Sep 13, 2010 10:35 pm
Lookin' good VPJ!
Proud of you for seeing it through, would be a good option for the jump industry.
G-
lowflyin'G3
lowflyin'G3's Photo gallery
Re: PT6 U206F
Postby Skydive206 » Tue Sep 14, 2010 7:28 am
The engine is hanging on. starter fitted, still needs the nose wheel and tire installed before rolling it outside for better pics. didnt want to take a chance and remove the engine stand until the nose wheel is on.
Skydive206
Re: PT6 U206F
Postby 58Skylane » Tue Sep 14, 2010 8:05 am
Just a small word of advise. Be careful using those nylon ratchet straps for very expensive items like whats pictured. I use those type of ratchet straps (motorcycle tie downs) inside my rig for securing heavy loads. So far, I've had a half dozen of those straps break at the ratchet assembly (the handles bend as I was tightening the strap and the load came loose). I'm pretty sure the factor was cheap (China made) tie downs.
I can't tell by the picture, but does look like your using heavy duty straps. But still, I'd be using metal chain for an expensive engine like that.
Other than that, looks like the conversion is coming along quit nicely.
58Skylane
58Skylane's Photo gallery
Re: PT6 U206F
Postby Savannah-Tom » Tue Sep 14, 2010 10:26 am
"She's really lookin' good, Vern"!
What will you do with all the empty space under the engine?
tom
Savannah-Tom
Savannah-Tom's Photo gallery
Re: PT6 U206F
Postby Skydive206 » Tue Sep 14, 2010 10:44 am
oil cooler, air inlet filter/separator, Batteries
Skydive206
Re: PT6 U206F
Postby Tadpole » Tue Sep 14, 2010 2:07 pm
I need to come jump that rocket!
Tadpole
Tadpole's Photo gallery
Re: PT6 U206F
Postby lancef53 » Tue Sep 14, 2010 6:06 pm
That is awesome!!
lancef53
Re: PT6 U206F
Postby 58Skylane » Tue Sep 14, 2010 6:15 pm
The heck with a Pponk conversion!! Can I put one of them in my 182??
58Skylane
Re: PT6 U206F
Postby Skydive206 » Thu Sep 16, 2010 6:50 am
A better view of the firewall reinforcements and engine mount. Prop clearance 600x6 nose, 800x6 mains shows that a standard King air 90 prop will work making things easy.
Skydive206
Re: PT6 U206F
Postby SkyTruck » Thu Sep 16, 2010 11:35 am
lancef53 wrote:Whats with the tailwheel turbine 206 in the gallery? Photoshop? Looks awesome!!
It's like you wrote this question with invisible ink!
'80 A185F
SkyTruck
SkyTruck's Photo gallery
Re: PT6 U206F
Postby Skydive206 » Thu Sep 16, 2010 6:00 pm
New outdoor photos. Not photo shop.
Skydive206
Re: PT6 U206F
Postby Tom » Thu Sep 16, 2010 7:45 pm
question, now what is that model pt-6 rated for?
Tom
Tom
Formerly "Cessna_Pilot"
Tom
FindMeSpot URL: http://share.findmespot.com/shared/face ... L4iDVGG6Zp
Re: PT6 U206F
Postby Skydive206 » Thu Sep 16, 2010 8:02 pm
PT6A-20 550 hp. Looking to limit it to 450 hp.
Skydive206
Re: PT6 U206F
Postby L-19 » Sun Oct 31, 2010 11:25 pm
Project update?
L-19
L-19's Photo gallery
Re: PT6 U206F
Postby Skydive206 » Mon Nov 01, 2010 6:09 am
No exciting stuff to show off like the engine hanging on the mount. The fiberglass Pitot engine inlet scoop being fabricated, wiring going in, Prop has been approved by Hartzell. All the little stuff that takes time and not real sexy. 90% done and 90% to go. When I have some new good photos Ill be sure to show off and post them.
Skydive206
Re: PT6 U206F
Postby Skydive206 » Thu Jan 06, 2011 9:09 am
Alot of looking, carving, looking, carving. Build up more foam, Carving, looking. The 206 is rounder than a Porter and flat sheet metal sides would just look wrong. I hope the finished product looks good and blends well with the original lines. Image
Skydive206
Re: PT6 U206F
Postby Skydive206 » Thu Jan 06, 2011 9:17 am
How long it is taking for the Cowl, Im starting to think it looks great without it. After putting an engine on it like that you should show it off. No woman should cover up a great boob job. With that much horse power who needs a cowl for drag reduction? Back to work.
Skydive206
Re: PT6 U206F
Postby lancef53 » Thu Jan 06, 2011 6:05 pm
That looks great!!
lancef53
Return to Modifications
