take-off with my stol kit
Re: take-off with my stol kit
Postby maules.com » Wed Apr 21, 2010 8:21 pm
Once&future, the technique should work equally for trigears as for taildraggers.
First trick is to judge getting your tail as close to the fence as possible as you come around followed by full power at a point about 20deg from takeoff direction (varies with aircraft and thrust).
The idea is you already have overcome tyre/wheel rolling resistance plus start and acceleration of the 'mass' and the bonus is that the prop is being moved into undisturbed/clean air, rather than turbulant/dirty air as in holding brakes and releasing, plus as noted, no rock damage.
maules.com
Postby once&futr_alaskaflyer » Wed Apr 21, 2010 9:20 pm
Thanks, I use the rolling takeoff quite often but always to the left because with my bird using p-factor to get it around 180 degrees is advantageous. It makes sense that it would help straighten out the right turn, the harder part is beginning the right turn :) especially on packed snow and ice! I'll play with it both directions now that we are back to bare ground.
Judicious use of throttle until one is assured of making the beeline down the runway is advised :O
Richard
'55 Cessna 170B, 165hp Franklin powered
Location: Keewenaw Peninsula, Michigan and Carson Valley, Nevada
Postby porterjet » Thu Apr 22, 2010 1:46 am
Wasted runway, Maule.com makes a good point. I saw two examples of it yesterday, not a shortfield situation but still bad technique. The first was a Beechjet that was 'position and hold" at least 1000 ft. down the runway. I have no idea what they were thinking. After he took off a G 4 lined up with about 250 feet of pavement behind them. On a 200 ft. wide runway there is no excuse for not being able to comfortably line up, without dragging the brakes, within 100 feet of the end of the pavement even in that class of airplane. ( I was next and used 23 ft..... :D )
John in Saudi
G2 (stol)
porterjet
Postby gbflyer » Thu Apr 22, 2010 8:26 am
Along with being sort of narrow and a little brushy, this spot is also kind of short. Will Crash make a J-turn here I wonder or power up with some brakes?
disclaimer: Pic borrowed from SC.org. Way above my pay grade. Yes, he lands there on purpose.:D
gbflyer
gbflyer's Photo gallery
Postby hotrod150 » Thu Apr 22, 2010 10:35 am
mtv wrote:......A Cessna 170 need not be a lame steering machine. Mine steers at least as well as ANY 180 or Cub, and better than most. I worked to modify the steering to improve. This was field approved out of the FAI office. It's pretty much a no brainer. Get in touch if you want more info. IT's not hard, and makes a world of difference. ...
I'd like to hear more about this. How about starting a new post to explain/discuss the mod?
Eric
minimums are for busting
hotrod150
Postby mtv » Thu Apr 22, 2010 2:00 pm
I'll post a picture. First, I'll have to TAKE one, of course. Might be a day or two.
And, that runway that Crash's airplane is on in the weeds is plenty long enough to leave without holding the brakes.
If you like your prop (and it's hard not to at the current price of props) DO NOT hold the brakes on stuff like this, and run up to full power.
mtv
mtv's Photo gallery
Return to Theory, Practice, and Procedures
