polishing aluminum
Have problems with your aircraft? Maybe just questions about regs or maintenance? Need to know the best way to do something?
polishing aluminum
Postby steve c » Tue May 16, 2006 5:23 am
I have been working away on my latest project, a '59 180...its its still in peices and it's just about time to get the polisher out, its never been polished, so i am starting from rock bottom, you know, 320 grit sandpaper marks, old n numbers etched in the skins, any ideas on the best process and stuff to use?
steve c
Postby Cubdude » Tue May 16, 2006 7:20 am
This stuff does a great job on pontoon boats but may be a little corrosive for an airplane.
http://www.zep.com/ProductCatalog/ProductBrowse.asp?img=vehicle&section=21&subSection=595&superSection=0&pageNumber=2
Cubdude
Postby hardtailjohn » Tue May 16, 2006 7:59 am
Steve, from experience, wet sanding will save you lots of polishing time... I usually go through 1500 grit. Do a google search, as it seems to me that someone referenced me to an article a year or so ago, and it was great! Good luck..that's the best year for the 180's in my opinion... and don't forget to post pics!!
JH
hardtailjohn
hardtailjohn's Photo gallery
Postby Kenny Chapman » Tue May 16, 2006 8:17 am
Go to www.perfectpolish.com. This is a site that is specifically for polishing aiplanes and airstream trailers.
"I remember when you took pride in just getting there." Frank Towns
Kenny Chapman
Kenny Chapman's Photo gallery
Postby steve c » Tue May 16, 2006 7:34 pm
cubdude, anything zep is some potent stuff, i would bet it works good but i have deeper scratches to contend with, i am with john, to wetsand. its probobly the best way to go, i just was hoping there would be a easier way! kenny, i looked at the site, it has some great ideas, i'll bet i end up using alot of them- thanks!i was also looking at some sites where they polish the big birds, way cool equptment! i will probobly wetsand as needed then buff it with a rouge stick first and see how that goes, i am looking for a satin finish, mirror would be too much work in the long run. thanks guys!
good judgement is from experience,
experience is from bad judgement......
steve c
Postby soaringhiggy » Tue May 16, 2006 8:30 pm
be carful with the zep stuff. Hydrofluoric acid (HF) is deadly stuff if it gets on your skin. I do not know the concentration of HF in that mix, but I would be very cautious with it.
The wounds that it causes are very deep and painful.
Dane
48 Stinson 108-3
soaringhiggy
soaringhiggy's Photo gallery
Postby Zzz » Tue May 16, 2006 8:37 pm
HF reacts with calcium, that's one of the reasons it's so deadly. It will seep thru your tissue until it gets to your bone and then react with that, destroying the bone.
I heard a horror story about a guy that was an artist in NYC who used massive amount of HF, enough to need a barrel. He disposed of it by putting it in a dumpter, and when the trash guy picked it up with the truck, the barrel was either crushed or opened and he got douched with the stuff. Needless to say, he died.
Zzz
Amateur
Zzz's Photo gallery
Postby qmdv » Tue May 16, 2006 9:40 pm
Hm. Polishing aluminum. Is that not the reason paint was invented. You could fly it to Yuma and find one of those folks that will do the kind of work that I will not do.
qmdv
qmdv's Photo gallery
Postby steve c » Wed May 17, 2006 4:19 pm
well, i did think about painting the wings and leaving the fues polished, any ideas?
steve---
steve c
Return to Maintenance and Parts Support
