Hi :
Just looking for some advice here, I 'm making the Pponk conversion (275hp) on my 182E, I'll also put the airglass nose wheel fork STC and will use 6:00 x 6 tires in the nose gear, with this size of tires, is there enough prop clearence for a 86" Mc 401 tri blade?? I ll use the plane as a jump plane so climb rate for me is the most inportant factor, and all the runways that we will be using are paved .
If any one run the same set up would like to hear from.
Thanks a lot for the help.
