bumper wrote:Aktahoe1,
I know you've decided on the Mac, but might still have a look at this test. You may well be walking away from a lighter, better performing prop if MT sells one in the size you need and w/ the appropriate STC.
While the props tested in the link below are not the same size as the one you are getting, I think the test results are still an eye opener. From my own experience w/ the Husky and that of the other posters on FlyHusky.com, the MT is absolutely positively the best performer on the "dog" - bar none. Further, 2-blades perform better than 3, which makes sense, as the less blades the less interferance drag (a 1-blade prop is actually the most effecient - - and they do have 'em!). 3 blades offer more ground clearance and are smoother, though MTs dynamically balance to turbine smooth in my experience.
see:
http://www.flight-resource.com/PTD/Cessna180-182.pdfDisclosure: Flight Resource is the NA dealer for MT . . . so one might expect their test results to favor the MT. In this case, I believe them.
bumper
Unfortunately, IMHO, the current MT 2 blade just isn't quite enough blade for the Pponk. It is really, really, good, just a tad bit under propped. I have run both back to back....
BUT... If fwd CG is an issue for you, it is the best solution out there... Bar none
MT truths and myths...
Wood core, yes.... Composite sheath yes.... The Mac will undoubtedly make a better tree trimmer, if that is your thing, this is the prop for you...
It is my opinion (and Steve Knopps) that a Mac will beat the MT off the ground at an airport in sterile test conditions, by about 3'. If Valdez style competitions are your thing, than this is the prop for you.... I try not to get into places that leave me a +\- 3 ft. Margin for error...
The Mac is uncontestedly cheaper, although not on the magnitude Russ reports. My 2 blade was factory new at $10,400, my 3 blade also new at A bit over $12k.If cheaper is your thing the Mac is again your choice.
Spool up make make a difference in your ops? The MT spools up like a two stroke, if you land short in the sticks, there is a good chance you are a 'throttle jockey' ... Simply no contest here.... The MT spools up (and down) almost as fast as you move the lever...
There are a group of pilots, that truly enjoy the feel of a good flyer in the air... It is also pure fact that the more weight you add to the nose of an airplane, the more it will lose from that wonderful feel, it will fly slower on the top end, it will fly faster on the bottom end...if you are one of those pilots who enjoy feeling an airplane fly, the MT will be your uncontested choice.
Want to simulate it? The weight difference is 35#s and all of that is ahead of the CG... It is simple math to figure out how heavy of a front seat passenger you will have to fly with (and without) to simulate the weight exchange...
Personally, if I were on the losing end of $40K - $50K for an engine / prop upgrade (and I have been there) I would not put weight in any internet hearsay type advice, I would get in and fly every engine /
Prop combination I was considering....
Take care, Rob
All of us are given sh*t in life, the smart ones grow from it...the rest fling it at each other like monkeys.
