Cary wrote:If your question is how fast will it cruise, it's still a Skylane, and so it will go faster, but not a lot. If you expect 150 knots, you'll be disappointed, but 135 or so will be doable. Your climb rate will improve markedly--that's where excess horsepower really helps.
SixTwoLeemer wrote:Hard to believe another 55 horsepower would net zero?
66skylane wrote:I have a 66 182 with pponk and with wheel pants i would average 138-140 kts groundspeed at 21" and 2400rpms. I have owned this airplane for several years and fuel burn ranges from 13.5 to 15 gph. I now bave bigger tires and no pants and get 135kts over the ground.
182dude wrote:Well with my impending engine build coming up with the O470-50 what can i really expect out of my wheelpanted skylane with this engine and hartzell 82" scimitar...
66skylane wrote:I have a 66 182 with pponk and with wheel pants i would average 138-140 kts ground speed at 21" and 2400rpms. I have owned this airplane for several years and fuel burn ranges from 13.5 to 15 gph. I now have bigger tires and no pants and get 135kts over the ground.
. TRUE AIR SPEED is. They are two very different things. I've seen 190 mph ground speeds, only means I've got a tailwind and I've come through a mountain pass with a 60 mph ground speed means a head wind. The air mass that you travel through is a variable that you cannot control.Glidergeek wrote:66skylane wrote:I have a 66 182 with pponk and with wheel pants i would average 138-140 kts ground speed at 21" and 2400rpms. I have owned this airplane for several years and fuel burn ranges from 13.5 to 15 gph. I now have bigger tires and no pants and get 135kts over the ground.
Ground speed is not a very accurate measurement. TRUE AIR SPEED is. They are two very different things. I've seen 190 mph ground speeds, only means I've got a tailwind and I've come through a mountain pass with a 60 mph ground speed means a head wind. The air mass that you travel through is a variable that you cannot control.
If you've got a GPS and most likely it's a Garmin it has an E6B function that can calculate your TAS. My 180 with 7" tires before the Pponk Trued out @ 2200rpm & 19" mp 149 mph consistently using the E6B. I saw 10.5 GPH on the fuel flow leaned 50* ROP. This was at 8500 - 9500' normally.
After Pponking, that same 2200 rpm & 19" MP, 7" wheels got me 161 TASsame altitudes and @ 50* ROP (Alcor single EGT/CHT) and 13 GPH (JPI 450 fuel flow). Then after several conversations with Steve Knopp he had me using carb heat in cruse and I use it in climb also, that trimmed my fuel flow by .5 gph, no speed penalty. No differences in engine temps.
Then I went to a JPI 700 engine monitorand have been running 2300 RPM & 19" same altitudes and able to (I think) more accurately lean to same 50* ROP and see 11.8 to 12.2 gph same TAS 160-161 mph.
i switched to 8.5" tires from 7" and lost 9-10 mph (TAS) same power settings.
lesuther wrote:55 extra hp nets you 7% more airspeed....that's all. Power required goes as the cube of the airspeed. So a stock ship that moves at 130 knots might gain 9 knots.
Climb power, on the other hand, is where things do better. If a 182 needs 85 HP to maintain level flight at gross, then 55 HP will net you a third more climb theoretically.
182dude wrote:..... what can i really expect out of my wheelpanted skylane with this engine and hartzell 82" scimitar...
Mike
lesuther wrote:SixTwoLeemer wrote:Hard to believe another 55 horsepower would net zero?
Cary wrote:... But my point is that adding 55 hp won't make it into a speed demon; it will climb dramatically better, but it won't go lots faster; it's just too draggy an airframe.
Rob wrote: lesuthers math almost works in a sterile perfect world...
Rob wrote:Everybody's pockets are different, I am thankful I get to fly at all...
!), I might consider it...Users browsing this forum: No registered users and 0 guests
