A brass wire wheel would make real short work of it, but something tells me i shouldn't scratch up the aluminum.
Any suggestions?
garth
gear wrote:Hi Zane - I tried that stuff - wouldnt touch it. I think im going to take it down to bare aluminum with a brass wire wheel and then when applying the contact cement, I'll make sure to cover all the bare aluminum with the cement - that should protect it.
garth
bart wrote:Be careful using a brass wirewheel on aluminum, you could be setting yourself up for dissimilar metal corrosion problems down the road. I'm no expert on the subject but I've seen the results of this process.
Return to Maintenance and Parts Support
