littlewheelinback wrote:but treat it as an aircraft with a suspect engine?
clippwagon wrote:Disclaimer: I'm not an engine guy.
...but, was the engine properly broke in during the ten hours after overhaul? If not, is it too late for that to happen?
SixTwoLeemer wrote:
I agree that its a crap-shoot anyway, no matter what the logbooks say. If the plane is straight and its what you want, buy it and enjoy every "free" hour you get and smile that you own an airplane! Personally I prefer a pristine airframe...engines are replaceable wear-items.... its the dents in the airframe that I loathe.
Many of my friends are still dreaming, waiting for the perfect plane with new engine, garmin panel, beautiful paint to come along for half price. The rest of us are out flying.
OregonMaule wrote:In 2001 my M7 had a prop strike.The engine went to Lycoming for the new crank and strike inspection, then sat from 2001 to 2006 with 30 minutes on it because the owner was afraid to fly it.
I got it and it has run perfect ever since. Then oil analysis tipped me that something was not right. 90% of the guys here and on the Maule site said open it, so I did and the rest as they say history.
I would highly discourage anyone from buying a plane with an airplane with an engine that set not pickled. If not pickled negotiate a tear down inspection. If you don't you are gambling. I gambled and lost.
Good day
OregonMaule wrote:From my experience: This thread has a lot more.
posting.php?mode=quote&f=14&p=109402OregonMaule wrote:In 2001 my M7 had a prop strike.The engine went to Lycoming for the new crank and strike inspection, then sat from 2001 to 2006 with 30 minutes on it because the owner was afraid to fly it.
Good day
mtv wrote:OregonMaule wrote:From my experience: This thread has a lot more.
Good day
Again, you cannot compare Lycoming engines with Continentals in this particular regard, for the reasons noted earlier. There is still some risk with a Continental that's sat for a while, but the risk is much lower, and the consequences typically less expensive than for the Lycomings.
