It's crucially important that if you use this program, the correct data needs to be entered first.
http://itunes.apple.com/us/app/cg-finder/id344805048?mt=8
182 STOL driver wrote:Anyone have a version for Android Smartphone ? I've got a Samsung "S" 4g for last few weeks and love it.
Zane wrote:As a user interface designer, I find it almost as offensive as the BCP website.
There are a bunch of other iPhone W&B apps out there. $5 is a small price to pay for something that looks better.
Here are a few:
http://www.wnbpro.com/
http://www.nextgen-systems.com/weightbalance/
You'd have to do a feature comparison, but W&B is such a simple function anyway.
The app does not display the straight line CG envelope like others. It's displayed as a set of sliders that are set between your initially entered aft cg and fwd cg range (34.5 and 41.8"). Make sure you entered your plane's plane's empty weight and ARM. You should have also already entered your aircraft maximum take-off weight (3350 lbs?). Press "calculate" and if all the numbers and sliders are green, you'll be within that cg range. If red, then you're either fwd or aft or overloaded. You can move sliders to adjust individual stations on the same screen and get an instant view of what moving x lbs x distance fwd or aft would do to within your cg envelope. The program's creator is very helpful and will respond the same day if you have other inquiries. stevemonty@me.comSkyTruck wrote:Question,
My plane FWD CG is a straight line variation from 34.5" @ 2100Lbs to 41.8" @ 3350Lbs.
I looked but can't find a way to enter data so the App knows whether I'm in or out of CG at various weights.
Any ideas?
Thanks
SkyTruck wrote:Make sure you put the Arm in inches.
If you put the arm in using the moment(devided by 1000), it won't display because it will be way off the graph(envelop).
Ask me how I know
It works great for me now I have the data entered properly.
Good luck.
Here are a few:
Weight?
Balance??????
Littlecub wrote:It it used in Alaska to figure out if the doors are gunna close-ahead of time?.....![]()
lc
Return to Products, Gear, and Technology
Users browsing this forum: Pundy and 3 guests
