RWM wrote:The trimmable horizontal stabilizer, instead of elevator trim, is also a good feature on the straight tails.
Manual flaps and spring steel main gear a plus, too.
motoadve wrote:I read many times , the 182 straight tail is prefered as a backcountry plane over the swept tail.
What are the differences , advantages, behaviour?
I know the older ones were lighter.
Never flown in one though.
Glidergeek wrote:"and 35 knot crosswinds are nothing to wrinkle my knickers over" Where can we meet to watch this![]()
I give a case of your choice of beverage to see you complete a true 35 kt crosswind landing. Entertainment factor only
lesuther wrote:Glidergeek wrote:"and 35 knot crosswinds are nothing to wrinkle my knickers over" Where can we meet to watch this![]()
I had a breezy day here in Longmont in early March during a blow of 28G30(something) right across the runway from the south. It wasn't 35G(something), but I never came close to running out of rudder. In fact, it was harder to keep things straight once I slowed down to roll off the runway. The limits are certainly well above 30.
The point is, the rudder in any 182 is capable of slipping things straight down the runway in a mighty big blow, and is not inadequate at all for a nosedragger.
Matt 7GCBC wrote:The straight tail is the most noticable aspect of those model years with the manual flaps and trimable horizontal stabilizer (as opposed to the elevator trim tab), so I think that's why people give that detail to look for... However, I tell folks to look at the 1960/61 year models as well, as they had all of these attributes except the straight tail. In fact they are also on the list of model years which can be converted to conventional gear. These had the swept tail, but also had the same fuselage as the later model skywagons with the third window. So if you converted it and put on a straight tail, it would look like a late model skywagon! The gear was the tallest on the 56 model and a bit shorter on the 57/58 and then pretty standard after that.
As far as the trimmable stab, I find that without it, the 182s loaded 2 up front tend to be more nose heavy and pilots will have more issue keeping the nosewheel out of the bumps.
. Motodave and FLIGHTmotoadve wrote:I read many times , the 182 straight tail is prefered as a backcountry plane over the swept tail.
Users browsing this forum: Google Adsense [Bot] and 3 guests
