Littlecub wrote:Why not lift the tail immediately with power application on TO?..... (if you have enough power)
Then hold the tail up with power while braking when you land-until you stop?... (if you have enough RW length)
It does sound like a high DA day, though.
Just askin....
lc
patrol guy wrote:you wouldn't need the valve if you had a can of Great Stuff to fill the tire with??
This is an opinion not burdened with anything like a real understanding or empirical data: that stuff is good for wheel barrow and hand truck tires. If you don't keep the wheel spinning until it congeals inside the tire/tube you will end up with a tire that is out of balance. I have no idea whether this is important on the tail of an airplane.S-12Flyer wrote:patrol guy wrote:you wouldn't need the valve if you had a can of Great Stuff to fill the tire with??
OK be gentle. Does that really work for a temporary fix?
I'm pretty sure that I would not use it on the mains but I wasn't sure if it would work in a pinch for a tailwheel to get you home without destroying your rim, tire and fork.Emory Bored wrote:This is an opinion not burdened with anything like a real understanding or empirical data: that stuff is good for wheel barrow and hand truck tires. If you don't keep the wheel spinning until it congeals inside the tire/tube you will end up with a tire that is out of balance. I have no idea whether this is important on the tail of an airplane.S-12Flyer wrote:patrol guy wrote:you wouldn't need the valve if you had a can of Great Stuff to fill the tire with??
EB
I suppose if a guy were ready and willing to sacrifice a tailwheel tube to science he could gather data on his own?S-12Flyer wrote:I'm pretty sure that I would not use it on the mains but I wasn't sure if it would work in a pinch for a tailwheel to get you home without destroying your rim, tire and fork.Emory Bored wrote:This is an opinion not burdened with anything like a real understanding or empirical data: that stuff is good for wheel barrow and hand truck tires. If you don't keep the wheel spinning until it congeals inside the tire/tube you will end up with a tire that is out of balance. I have no idea whether this is important on the tail of an airplane.S-12Flyer wrote:OK be gentle. Does that really work for a temporary fix?
EB
However, I would like to see the peer reviewed double blind study and the NASA calibration data that you used for your opinion.
