Alc free gas disapearing
Re: Alc free gas disapearing
Postby 180Marty » Tue Apr 10, 2012 8:36 am
lesuther, I was arguing on Supercub with an unhappy Texas cattle guy. Because corn is not subsidized anymore he can't afford to haul it down to Texas and is unhappy that Iowa is the cattle feeding place of choice now. Here is part of my response. We are closed loop up here now. Ethanol, wet distillers hauled back to the local feedlot, my corn field gets the manure/fertilizer to produce another crop----no commercial fertilizer necessary.A lot of the Texas manure fertilizer value was wasted before.
I don't get any money from the gov't because of cheap corn anymore. I take it you are one of the unhappy Texas feedlot guys---my neighbors just put up a 1000 head mono slope cattle confinement(they are feeding a little over 30% wet distillers( no drying cost) in the ration) and I will get the manure/fertilizer to put on my field saving me a bunch of $$$$( won't need $800 anhydrous,phoshate from Florida,and potash from Canada). The farthest point from the confinement on my farm is a 1/2 mile( very efficient). These mono slope feeders up here in Iowa sure don't want to see anything bad happen to the ethanol industry.
Cow/calf and stocker operation. We now sell our calves heavier without taking them to the yard. Doesn't pencil to feed anymore. Logistics are in your neighbors favor. My area is a net importer of corn and the expenses associated with that make it no longer profitable or at least make the risk reward ratio unfavorable. Ethanol industry is mature enough to stand on its own now.
I'm not going to argue about it anymore. I know its a waste of time discussing with an embedded stakeholder but My pocketbook and everyone else's here is all the proof we need.
Postby hotrod150 » Tue Apr 10, 2012 10:24 am
My Cessna owner's handbook doesn't specifically say no car gas but it DOES say no ethanol. My EAA mogas STC sez no ethanol, as did the Petersen STC in a previous plane. As soon as someone official (Cessna, FAA, Petersen, EAA) tests & specifically approves E10 as being safe in my airplane, I'll use it if necesary. But at least til then, I'm hoping E-zero will remain available.
I'm down to two local sources, but have been hearing about increasing availability in the north-of-Seattle area at Cenex & 76 stations so am keeping my fingers crossed that it starts happening over here on the Olympic Peninsula.
Marty, you have time & money invested in ethanol production & I wish you well, I just don't want it rammed down my throat. If ethanolized fuel has merit, it will sell on an open market -- in other words, right alongside E-zero pumps.
Postby courierguy » Tue Apr 10, 2012 12:08 pm
When comparing mo gas prices to av gas, don't forget that if you keep good records and proper receipts YOU CAN FILE AT THE END OF THE YEAR AND GET THE MO GAS ROAD TAXES BACK! Just went over that yesterday with my bean counter.
And no, I do not cheat, it'd be bad flying mojo to do so, illegal, plus nothing I drive needs higher octane fuel, I keep it real. I do use the money back at the end of the year to buy more mo gas, doing so today.
I also file to get the road tax back for a certain percentage of the diesel fuel I use every year in the crane, as it is used "off road", operating, once I get to the jobsite. A legite deduction 8)
Postby lesuther » Tue Apr 10, 2012 1:45 pm
180Marty wrote:lesuther, here is an email from a friend that designs ethanol plants. They are spending their money to do research to prove the BS you want to believe is wrong.
I'm glad it's still a free country. Chemistry and thermodynamics *are* simply theories, after all...along with those so-called 'laws' of gravitation...
180Marty wrote:The oil companies do not want competition and will do whatever it takes to attain it. How much actual research have you done?
None beyond what any other physicist, chemist, or engineer with an interest has done.
180Marty wrote:I'm guessing the Focus engine I'm getting is retarded quite a bit when the 87 octane is being burned and advanced when E85 is burned. Also, I understand that ethanol expands more that gas when it is burned creating more push when the piston is going down.
As I mentioned in my post, "flex fuel" cars, or cars built specifically to burn alcohol blends, can advance the ignition to the onset of detonation appropriately for the fuel. This slightly increases efficiency while burning alcohol at higher RPM, and almost not at all while turning at very low RPM. This ability is not available to folks flying certificated equipment.
Also as mentioned, blended fuels can be used at higher compression ratios, which boosts their thermal efficiency (which is a big part of the reason behind the efficiency differences of a diesel cycle versus otto cycle engines). For an engine with a compression ratio and timing regime tuned for gasoline, these improvements are not available. Certain variable compression ratio cycles (i.e. some types of Atkinsons, like some variable valve BMW systems) can widely vary the effective compression ratio to capture some of the benefits of higher thermal efficiency. Or you can switch to a diesel cycle, which is a very different ball of wax since it it inherently more thermodynamically efficient with higher compression ratios *and* you don't need to bother with stoichiometric ratios.
Alcohol blend fuels have a higher heat of vaporization. That means the stoichiometric fuel/air mixture is cooler going into the cylinder than for E0 gasoline. This doesn't sound like much, but it is a huge deal. The thermal efficiency of the cycle is a function of the temperature differences of the maximum flame temp, the exhaust gas temp, the ambient temperature the car is driving in, and the intake temp. If you cool the intake charge more, you lose efficiency. It's about 5% right off the top for E10(the induction temp narrows the temp difference by a whopping 5%) . Note I didn't say power- I said efficiency. You have to burn more fuel to make up for this loss. In addition, alcohol has less energy by weight or by volume than E0. You need 1.5 gallons of ethanol to equal the energy in a single gallon of gasoline. If you add alcohol to gasoline, you reduce the chemical energy of the fuel. In fact, you'll need 2% or so more E10 to match the chemical energy of E0. If you add up the induction cooling losses to the chemical deficiencies, you'll end up losing around 7% on mpg. Most modern cars adjust their timing with knock sensors and can recover a few percent mpg, and most cars will see a drop of a few percent mpg. Much older cars will not recover the losses. This is also the case in planes.
Airplane engines simply don't adjust their timing, and they use relatively low compression. They do not recover the efficiency lost from the induction cooling or chemical losses. You are left with lower HP production and lower efficiency. If you prefer, I can point to any number of well-used references to these facts. Plus every car I've used gets lower mpg on ethanol.
180Marty wrote:This is why many who contend a btu is just a btu don’t recognize mileage benefits with ethanol.
To a physicist, chemist, engineer, or a lay person, it really doesn't matter: A Btu is a Btu. It's actually a sort of well-known joke/truism in thermodynamics circles. An Otto cycle engine designed to burn alcohol can achieve a higher thermal efficiency than an Otto cycle engine burning gasoline. That is a fact, *and* the problem- our engines have a fixed compression ratio and ignition timing, so we are left with *less* efficiency and power. A purpose built alcohol engine can wring more out of every Btu of fuel energy. A blended fuel compromise generally can't.
180Marty wrote:Particulate emissions went up when we didn’t increase the amount of aromatics but simply changed the distillation of aromatics. This is what Honda had demonstrated over a year ago and CARB went out of their way to discredit.
Nobody argues that alcohol can help reduce particulates, CO, and unburned hydrocarbons (aromatics included). Alcohol blends have improved air quality all over the nation. Period. The benefits are rather large for E5 in older and newer engines alike. The improvements for E10 are difficult to discern (translation: almost non-existent).More than that- lots of externalities to fix (like compatibility).
180Marty wrote:E30 performed very well. Not that E85 didn’t do good but the fuel flow and additional cooling effect limited some of the emission benefits. This is not due to the fuel as much as OEM’s don’t have to surpass emission requirements, just meet them.
Your friend just repeated the part about induction cooling losses I described above. He is telling you the same thing.
180Marty wrote:I am seeing that the standard EPA procedures to change from fuel to fuel doesn’t allow vehicles to fully adapt, primarily the ignition. Emission control takes priority in short fuel trim and long term fuel trim can take over 40 miles.
Your friend is correct. People wonder why American cars always have lower mpg than the same model in Europe. Part of it is weight- we like to be safer in a wreck in the US. We also like more HP. But emissions is also a big part of the puzzle. You'll know why when you go visit a large eastern European city the moment you step out of the airport. Ignition is important because as you advance the timing to improve high RPM efficiency, you increase NOx emissions (higher flame temps, longer combustion duration=higher efficiency, worse air).
180Marty wrote:We had two of three vehicles get equal mileage with E30 for the heavier of the three drive cycles. Driving habits do matter in all of this.
Your friend just stated that mpg drops with E30 (equal+equal+(less than equal))/3=(<equal mpg). He knows this too, apparently.
Remember that the ethanol lobby has shown that car engines can likely manage to burn more ethanol. This is a far cry from saying we should burn more ethanol. That is likely why the EPA says "who cares". There is no emissions benefit, and compatibility issues abound with high blend alcohols. And as I mentioned before, more alcohol does not mean any less foreign oil from people we'd rather not be dependent on. The oil we don't buy from them to turn into gasoline will be the oil we buy from them to grow our food and ethanol.
Postby 180Marty » Tue Apr 10, 2012 5:20 pm
I just stopped at the brand new blender pumps that I have been trying to get the local Co op to install since 2003. It has E0 87octane priced at $3.849, E10--89octane@ $3.799, E20 and E30---should be around94 octane, can't remember the price, and E85 @$2.959. Sure is nice to push one button instead of having to figure how many gallons of this and that. 89 penny spread isn't to bad between E0 and E85. The Focus was fueled with Minnesota E10 at the dealer so I could only squeeze in a couple of E85 and by the time I got home the tank average was up to 38.5 mpg.
Postby Zzz » Tue Apr 10, 2012 5:29 pm
Thread = Deja vu
Never gets tired.
Postby Mongo » Tue Apr 10, 2012 5:47 pm
I have used E-10 over that last two years about 65-75% of the time for a total of about 300 hours. I have had only one issue in this time period, the tygon tubing I use for my sight gauges gets hard, but I just replace it at the annual. I should mention that all of the other lines, oil included have been replaced with very light weight BMRS teflon/kevlar lines.
I don't let the fuel sit more than a month, and the one time I did I topped of the tanks with 100LL.
I actually trust E-10 more than 100LL as I have had plugs lead foul in flight and that is no fun, and yes I lean.
Sent from my HTC Evo using Tapatalk
Mongo
Mongo's Photo gallery
Postby fern_hopper » Tue Apr 10, 2012 10:31 pm
Zane wrote:Thread = Deja vu
Never gets tired.
Well I guess the ethanol horse needed another good beating. Time to grab the popcorn.........
Matt
fern_hopper
fern_hopper's Photo gallery
Postby hotrod150 » Wed Apr 11, 2012 10:16 am
courierguy wrote:........ if you keep good records and proper receipts YOU CAN FILE AT THE END OF THE YEAR AND GET THE MO GAS ROAD TAXES BACK! .........
In Washington, how that works is that they give back the road tax but take sales tax & aviation tax, and you get back the difference. When gas is cheap is works out to be a lot (relatively speaking), when it's expensive not so much. In the past I've gotten back (near as I can recall) up to maybe 15 cents a gallon-- now, with mogas in the $4/gallon range, the refund is about 2-1/2 cents per gallon. Hardly worth the trouble, but it does pay for a lunch every 3 months or so if I fly a fair amount, plus my tax contribution helps pay for airport stuff not roads.
Postby RanchAero » Thu Apr 12, 2012 7:12 am
I just got back to Olympia, WA from working out of town for a year and found out that 92 octane MOGAS is available in Olympia at Fast Fuel on Lilly Rd, (between Martin Way and Pacific). When I get by there I will look at prices. It is probably 5-6 miles from the airport. This is the first that I've known it was available in Olympia. I can't use it in my airplane...but it's going into the mowers and power saws, etc.
1976 Maule M5-235C
RanchAero
RanchAero's Photo gallery
Postby hotrod150 » Thu Apr 12, 2012 9:33 am
Yeah, there are still a few sources around. Some of the CFN cardlocks on the Olympic Peninsula have it, ditto some of the Cenex/Co-op's in the Snohomish area, also some 76 stations in the Arliongton/Mount Vernon area seem to selling E-zero now. I'm hoping the number of sources will continue to expand, not shrink.
Postby hotrod150 » Fri Apr 13, 2012 6:58 pm
hotrod150 wrote:.....In Washington, how it works is that they give back the road tax but take sales tax & aviation tax, and you get back the difference. When gas is cheap is works out to be a lot (relatively speaking), when it's expensive not so much......
Just turned in the paperwork for my Q1/12 fuel tax refund. Got back a letter from the Dept of Licensing that said when fuel prices rise above $3.78 per gallon, the aviation tax & sales tax add up to more than the road tax-- in other words, no refund. Bummer.
Postby Hafast » Thu Jun 21, 2012 2:28 pm
An effort in Iowa to change labeling requirements on gas pumps across the state to only require labeling for unblended gasoline and E85 officially died when the legislature adjourned for the year. SEMA actively opposed the bill. Current law in Iowa requires labeling when gasoline is blended with any amount of ethanol. If the bill had been enacted into law, it would have removed labeling requirements for ethanol-blended gasoline containing 15% or less ethanol, thereby increasing the risk of misfueling and potential engine damage.
Unblended gas is required to be labeled, but no guarantee was made that unblended gas would be available. The U.S. Environmental Protection Agency has been urged to create national labeling requirements for ethanol-blended gasoline that are placed as close as possible to the pump’s product selection mechanism, but since such requirements are not currently in place, vehicle owners must rely on state labeling requirements for information about the gasoline they use in their vehicles. Many products in the marketplace, including older cars, use materials that are incompatible with ethanol.
For details, contact Steve McDonald at stevem@sema.org.
Hafast
Hafast's Photo gallery
Postby dirtstrip » Thu Jun 21, 2012 4:31 pm
What goes around......
We are legalizing the sale of a new comer to our side of the state. E-0 85 octane straight gas is going to be legalized with an executive emergency measure as long as it is correctly labelled. 85 octane has been officially illegal to sell in this state but has been sold in western SD ( Rapid City) since the early days of cars. It always worked ok for vehicles at higher elevations but was never sold in the eastern part of the state. With high prices of gas and station/suppliers looking for every break, straight 85 octane is being slipped in as 87 or E-89 and has caused some problems at lower elevations. There are reports of engine damage. You don't know your getting it and most auto companies won't approve it. BUT.. there is a coming gasoline shortage approaching us and to remove it from at least the traditional market area now will hasten the shortage.
I should re-title this one to Alc Free Gas Appearing.
http://www.cspnet.com/news/fuels/articl ... -gas-rules
Postby 180Marty » Thu Jun 21, 2012 8:34 pm
And here I thought that they just wanted people to know that when they were putting 87 octane in the their tank that it was 10% ethanol and 90% crap,rot gut, 85 octane gasoline. Didn't realize SD would let people knowingly put 85 octane in their tank in the eastern part of the state----that should void engine warranties. Here in Iowa I know that 87 is straight gas and I never buy any.
Postby dirtstrip » Fri Jun 22, 2012 9:46 am
dirtstrip wrote:What goes around......
It should go without saying that since there are still many places that sell E0 87 and premium E0 91 octane in this state, when you buy either for aircraft use it is not sufficient to test just for ethanol. You should be aware that the octane may not be what is labelled. Hopefully this will get straightened out with the labeling but will unfortunately not improve the honesty of those intending to slip one by the customer.
Postby Fred54 » Fri Jun 22, 2012 4:36 pm
lesuther wrote:
180Marty wrote:And as I mentioned before, more alcohol does not mean any less foreign oil from people we'd rather not be dependent on. The oil we don't buy from them to turn into gasoline will be the oil we buy from them to grow our food and ethanol.
That isn't my understanding. Sure we use plenty of diesel for food production and transportation, but don't leave natural gas out of the equation. The manufacturer of fertilizer is primarily from natural gas, an energy source that for much of the foreseable future is domestic and inexpensive. I have no problem watching farmers and ethanol plants use a inexpesive domestic, clean burning form of energy that won't easily be used by my car into a liquid alcohol that I can use with little or no modification. Why not just burn the NG in your car? There is something to be said for effieciency via shortening the distance between energy production and usage, as in why not just use NG cars? A few years ago, I checked on a new over the road diesel tractor for a several hundred mile a day local route. The NG option required shipping the new truck up to BC, a few months, and doubled the price. It will payback after a few years, but for the bulk of the internal combustion engines out there, that conversion to NG isn't going to happen and even if it did, the refueling infrastrure isn't present. However, most of us can run a blend of ethanol today. If we say adious to a bunch of clean buring cheap NG to get our ethanol, so be it.
Fred54
Fred54's Photo gallery
Postby tcraft » Fri Jun 22, 2012 7:41 pm
Get alcohol free gas at my cousins gas station today he told me at last delivery he could only get 300 gallons because that was all his supplier had available at the time. I guess supply and demand have met . this really sucks I just want normal gas for my STC six dollars is not going to work on my budget
shawn coleman
2202T
tcraft f-22
tcraft
tcraft's Photo gallery
Postby Fred54 » Fri Jun 22, 2012 8:56 pm
tcraft wrote:Get alcohol free gas at my cousins gas station today he told me at last delivery he could only get 300 gallons because that was all his supplier had available at the time. I guess supply and demand have met . this really sucks I just want normal gas for my STC six dollars is not going to work on my budget
Have you tried the mogas over at the Payette airfield?
Fred54
Postby tcraft » Fri Jun 22, 2012 8:59 pm
Ya if in area 60 miles from my strip but will use it need to
shawn coleman
2202T
tcraft f-22
tcraft
