Cessna 170B Sportsman STOL: PIREP
Postby robw56 » Mon Apr 16, 2012 6:47 pm
As most of you know I got a Sportsman STOL kit for my 170. I picked up my plane from Q-Aeromotive in California City yesterday and flew it home. First I went up for a little bit with glidergeek in the right seat and we did some slow flight and a few stalls and only one landing back at Cal City before flying back to Rio Vista. Today I went out by myself to see what it could do and I was even more impressed with the kit, I think having less weight and not as mush of a forward CG changed the feel a little from the first flight test. First I did some slow flight with 20 degrees of flaps and power, I could keep it level at about 35mph and start to get a slight buffet. Next I tried 40 degrees with power... this time I was flying with the ASI below 30mph. At this point you could take the yoke all the way back put in full power the ASI is fluttering back and forth between 0 and 20 and it still doesn't really want to stall. Power off stalls with 40 degrees of flaps are impossible, it would just decend at about 600fpm at 40mph indicated. You can make turns back and forth at this speed with no problem. Next I went and shot a few landings at Rio Vista on the grass next to the taxi way. Yesterday when I flew I just approached at 60mph and it felt like it used to at 70mph. Today I was flying approaches at 45mph indicated and carrying power. WOW before there was no way I could do this. Before if I got a little below 60 you could feel the plane want to drop out from under you. Not anymore, 45mph carrying power into the flair and I would plop down on the grass nice and soft and stop in about 100 feet or less... I also had about a 15mph head wind. I felt like I was flying a helicopter on approach. Taking off with 20 degrees of flaps I'm airborne at 35 mph and climbing out nicely at 45mph. Stene's site lists VX at 48mph and VY at 75mph at gross. Also on the flight back from Cal City I noticed no loss in cruise speed. Overall I'm very happy with the kit and glad I got it. I'm looking forward to seeing what it can do in the backcountry this year. I hope this review can help anyone that's interested in installing the kit on their Cessna.
1953 Cessna 170B
robw56
FindMeSpot URL: http://share.findmespot.com/shared/face ... mDEpenHedH
robw56's Photo gallery
Re: Cessna 170B Sportsman STOL: PIREP
Postby akflyer2001 » Mon Apr 16, 2012 7:08 pm
Nice plane, what is the HP.?
Ken in Alaska
akflyer2001
akflyer2001's Photo gallery
Postby robw56 » Mon Apr 16, 2012 7:09 pm
145!!! :mrgreen:
1953 Cessna 170B
robw56
Postby kevbert » Mon Apr 16, 2012 7:27 pm
Outstanding, Rob! Thanks for sharing the data, that is most helpful. However, the airspeed indicator isn't very accurate in high angles of attack, so if you ever have the chance to measure ground speeds with a gps on a calm day, I'd be interested in hearing the results.
The voices keep telling me to put an STOL kit on my 1959 172. I think it has exactly the same wing as yours, so I would expect almost identical results. I'd better start buying lottery tickets. :oops:
kevbert
kevbert's Photo gallery
Postby mountainmatt » Mon Apr 16, 2012 7:39 pm
Awesome Rob! =D>
180A
Backcountry flying videos: FlyingPoochProd
mountainmatt
mountainmatt's Photo gallery
Postby 260Driver » Mon Apr 16, 2012 7:44 pm
Nice Rob! She looks real pertty now. With the STOL kit and the bushwheels you've been pretty busy. =P~
260Driver
260Driver's Photo gallery
Postby Tadpole » Mon Apr 16, 2012 7:47 pm
That's awesome!
Tadpole
Tadpole's Photo gallery
Postby Glidergeek » Mon Apr 16, 2012 10:34 pm
Rob
Thanks for the ride yesterday, quite impressed with the performance. And what's up with the "I think having less weight and not as mush of a forward CG changed the feel a little from the first flight test" :lol: I used to be as skinny as you 40 yrs ago, you just wait :D
Postby richw56 » Mon Apr 16, 2012 10:55 pm
Sometimes when Rob gets home he gets to borrow a 1959 STOL 172 that lives on our strip. Rob’s 170 with the seaplane prop has a better feel at the flare then the STOL 172 before Rob put on the STOL kit, so bring the 170 home some your old Dad can check it out. :D
This 172 also has some flap gap seals on it, I think that is a bad combo, it just has a hard time keeping that dam training wheel off the ground on flare. On take off pull the yoke all the way back and it fly’s off at 35 mph indicated at near gross.
Cessna 120 lyc O290D 125HP
Stinson 108-3
richw56
richw56's Photo gallery
Postby lesuther » Tue Apr 17, 2012 7:02 am
Very cool.
The Stene Sportman site says the modification "Nearly doubles lift coefficient". Their numbers hint at a 31% increase at Vy: Old Vy=80, new Vy=70; Cl(new)/Cl(old) = V(old)^2/V(new)^2=1.31=31% more. It seems neat regardless. It sounds like you might get more AOA, which would also increase the Cl max a lot more than a comparison at Vy.
Is there any mention of a maneuvering speed reduction in the flight supplements, or were they able to certify it without a change?
Did you find the pitch was less nose-heavy, or more nose-heavy?
Postby robw56 » Tue Apr 17, 2012 7:49 am
With the seaplane prop I already cruise well below Va anyways and I haven't heard of it changing because of the Sportsman STOL. There aren't any flight supplements. I haven't noticed it being more or less nose heavy either.
1953 Cessna 170B
robw56
Postby robw56 » Tue Apr 17, 2012 8:06 am
Here is a short cell phone video of the first takeoff at Cal City
1953 Cessna 170B
robw56
Postby hotrod150 » Tue Apr 17, 2012 8:50 am
I think the sportsman kits are about $2K, what was the installed price? I tried to cheap out so bought a VG kit for my C150XP, but was underimpressed with the results-- there is some improvement but it is subtle.
Postby robw56 » Tue Apr 17, 2012 9:04 am
Install cost me 1k.
1953 Cessna 170B
robw56
Postby oldtech » Tue Apr 17, 2012 9:19 am
Attaboy! That's what that plane needed. Check out the improvement in glide ratio too. it's a good thing they have the big flaps
Airspeed, Altitude, Brains. You need 2 of the 3!
The Oldtech
oldtech
Postby EZFlap » Tue Apr 17, 2012 9:27 am
Alan Quackenbush at Q aeromotive is good people. A good mechanic, airplane lover, and a lifetime airport rat of the highest order.
EZ FLAP is like big bush tires for your flap system. ~ 100% Money back if you don't LOVE it ! http://www.ezflaphandle.com
EZFlap
EZFlap's Photo gallery
Postby Zzz » Tue Apr 17, 2012 9:56 am
Are you going to keep the cuffs unpainted aluminum? Looks kinda cool. Maybe a clearcoat or something?
Postby c170pete » Tue Apr 17, 2012 10:00 am
I'm sold. I just need permission from the wife... :o :shock: :x [-X :lol:
c170pete
c170pete's Photo gallery
Postby robw56 » Tue Apr 17, 2012 10:30 am
Zane wrote:Are you going to keep the cuffs unpainted aluminum? Looks kinda cool. Maybe a clearcoat or something?
It will stay unpainted for now. Eventually I'd like to do an entire strip and repaint.
1953 Cessna 170B
robw56
Postby buzzlatka » Tue Apr 17, 2012 10:34 am
How much weight did it add?
buzzlatka
buzzlatka's Photo gallery
Return to Modifications
