IO 360 on Mogas
IO 360 on Mogas
Postby qmdv » Fri Mar 16, 2012 7:50 pm
Talked to a guy that has a Maule with a Continental IO 360 in it. He was wondering about running 91 octane eth free auto fuel. He said that there is an stc for the plane but not that engine. We all know that there are two reasons why some engines do not have stc for mogas. First, not enough market to pay for testing and Second it was tested and failed.
The IO 360 is 8.5 to 1 compression. The Lycoming O 360 A1A is also 8.5 to 1 and it has a Peterson stc for mogas (91 octane). Then how about a Continental IO 470 with 8.6 to 1 comp ratio in a C 180.
Your thoughts. I know the legality but what if these engines were in an experimental.
qmdv
qmdv's Photo gallery
Re: IO 360 on Mogas
Postby M6RV6 » Fri Mar 16, 2012 8:15 pm
The main reason there is no STC for mogas on an injected engine is vapor lock as I understand it?
Has to do with the fuel system and spider!
That's what I have been told, also that if under 5000' it was not a problem, have run mogas in a io520 one time on an emergency, but was at sea level and did not use all the HP.
My $.02
Have as much Fun as is Possible and don't get Caught!
Keep SMILIN!
Brousard
Wilga
C210
M6RV6
M6RV6's Photo gallery
Re: IO 360 on Mogas
Postby OregonMaule » Fri Mar 16, 2012 8:31 pm
There is more to the auto gas STC than a piece of paper and a sticker. My O 540 has the Peterson STC. 2 electric fuel pumps besides the engine driven one. Engine driven pump has a scoop and scat tube directed in the pump. Scoop to the gascolator. One electric pump runs all the time the engine is on. The 2nd pump is turned on by a switch during TO and landing. A very detailed operation manual for most scenarios you may encounter.
You can burn what you want and be a test pilot I guess :shock:
Don't just be mad about people in our country illegally. DO SOMETHING POSITIVE !
http://www.numbersusa.com/content/
OregonMaule
OregonMaule's Photo gallery
Re: IO 360 on Mogas
Postby Resky » Fri Mar 16, 2012 8:48 pm
As gmdv said, the IO-470 in a Debonair has a STC for mogas - thats the 225 hp one. Thats the only injected one I know of, but I don't know much about the Peterson STCs.
Resky
Resky's Photo gallery
Re: IO 360 on Mogas
Postby dirtstrip » Fri Mar 16, 2012 8:52 pm
qmdv wrote:Your thoughts. I know the legality but what if these engines were in an experimental.
That just becomes part of your experiment.
Re: IO 360 on Mogas
Postby hotrod150 » Sat Mar 17, 2012 9:14 am
OregonMaule wrote:... My O 540 has the Peterson STC. 2 electric fuel pumps besides the engine driven one. Engine driven pump has a scoop and scat tube directed in the pump. Scoop to the gascolator. One electric pump runs all the time the engine is on. The 2nd pump is turned on by a switch during TO and landing. A very detailed operation manual for most scenarios you may encounter. ............
The Petersen website sez the mogas stc for the lycoming powered maules are available from Ray Maule. Does petersen own the stc & ray maule sells/controls it? Apparently the mogas stc for at least some of the cherokee models is similar to the maule stc-- extra fuel pumps, etc.
What did that stc cost, with the extra pumps etc, and what was the installation time? Normally a mogas stc costs $1.50/horsepower & installation costs are minimal-- paperwork, placards for the engine & airframe, & checking to make sure a plastic carb float is not installed.
Yes Petersen has an stc for the IO-470 Cont, it even looks like it is for 87 octane, but it looks like that's the only injected engine-- no IO-360 Lyc, no IO-360 Cont, no IO-540 Lyc, no IO-520or 550 Cont. No 220 Franklin either.
BTW EAA only holds 87 octane (low compression) mogas stc's, EAA has both low-comp (87 octane) & hi-comp (91 octane) stc's.
A guy named Blue Leader from the 170 site (may have been on here also?) used to swear by mogas for his IO-360 powered C170, claimed he never had a problem. I think he wrecked it but don't believe that had much to do with the fuel. :oops:
Re: IO 360 on Mogas
Postby iceman » Sun Mar 18, 2012 10:26 am
sure would be nice to go to mo gas.... :idea:
iceman
iceman's Photo gallery
Return to Modifications
