A Tough Bird B-17. ME109 crashed into Bomber
Postby OregonMaule » Thu Apr 14, 2011 4:57 pm
An absolute amazing story that has to be read.
A Tough Old Bird; An incredible story - what an incredible airplane!
A mid-air collision on 1FEB1943 between a B-17 and a German fighter over the Tunis dock area became the subject of some of the most famous photographs of World War II.
An enemy fighter attacking a 97th Bomb Group formation went out of control, probably with a wounded pilot, then continued its crashing descent into the rear of the fuselage of a Fortress named All American, piloted by Lt. Kendrick R. Bragg, of the 414th Bomb Squadron.
When it struck, the fighter broke apart, but left some pieces in the B-17. The left horizontal stabilizer and elevator of the Fortress were completely torn away.
The two right engines were out and one on the left had a serious oil pump leak. The vertical fin and the rudder had been damaged, the fuselage had been cut almost completely through – connected only at two small parts of the frame and the radios, electrical and oxygen systems were damaged. There was also a hole in the top that was over 16 feet long and 4 feet wide at its widest and the split in the fuselage went all the way to the top gunner’s turret. Although the tail actually bounced and swayed in the wind and twisted when the plane turned and all the control cables were severed , except one single elevator cable still worked, and the aircraft still flew-miraculously!
The tail gunner was trapped because there was no floor connecting the tail to the rest of the plane. The waist and tail gunners used parts of the German fighter and their own parachute harnesses in an attempt to keep the tail from ripping off and the two sides of the fuselage from splitting apart. While the crew was trying to keep the bomber from coming apart, the pilot continued on his bomb run and released his bombs over the target.
When the Bombay doors were opened, the wind turbulence was so great that it blew one of the waist gunners into the broken tail section. It took several minutes and four crew members to pass him ropes from parachutes and haul him back into the forward part of the plane. When they tried to do the same for the tail gunner, the tail began flapping so hard that it began to break off. The weight of the gunner was adding some stability to the tail section, so he went back to his position.
The turn back toward England had to be very slow to keep the tail from twisting off. They actually covered almost 70 miles to make the turn home. The bomber was so badly damaged that it was losing altitude and speed and was soon alone in the sky.
For a brief time, two more Me109 German fighters attacked the All American. Despite the extensive damage, all of the machine gunners were able to respond to these attacks and soon drove off the fighters. The two waist gunners stood up with their heads sticking out through the hole in the top of the fuselage to aim and fire their machine guns. The tail gunner had to shoot in short bursts because the recoil was actually causing the plane to turn.
Allied P51 fighters intercepted the All American as it crossed over the Channel and took one of the pictures shown below. They also radioed to the base describing the empennage was “waving like a fish tail†and that the plane would not make it and to send out boats to rescue the crew when they bailed out. The fighters stayed with the Fortress taking hand signals from the Lt. Bragg and relaying them to the base. Lt. Bragg signaled that 5 parachutes and the spare had been "used" so five of the crew could not bail out.
He made the decision that if they could not bail out safely, then he would stay with the plane and land it. Two and a half hours after being hit, the aircraft made its final turn to line up with the runway while it was still over 40 miles away. It descended into an emergency landing and a normal roll-out on its landing gear. When the ambulance pulled alongside, it was waved off because not a single member of the crew had been injured.
No one could believe that the aircraft could still fly in such a condition. The Fortress sat placidly until the crew all exited through the door in the fuselage and the tail gunner had climbed down a ladder, at which time the entire rear section of the aircraft collapsed onto the ground. The rugged old bird had done its job.
Don't just be mad about people in our country illegally. DO SOMETHING POSITIVE !
http://www.numbersusa.com/content/
OregonMaule
OregonMaule's Photo gallery
Re: A Tough Bird B-17. ME109 crashed into Bomber
Postby Rooster Cogburn » Thu Apr 14, 2011 7:47 pm
My dad flew B-17's, I can still hear some of his stories. I have walked through one, so I can understand what he was describing at times. Probably going to do a ride along this year at OSH.
Rooster Cogburn
Postby EZFlap » Fri Apr 15, 2011 9:45 am
Funny this thread should be up right now. Our EAA chapter is hosting the "Aluminum overcast" B-17 at Van Nuys airport this weekend. What a great airplane, that brings tears to the eyes of the old folks, and brings history alive for the younger folks.
EZ FLAP is like big bush tires for your flap system. ~ 100% Money back if you don't LOVE it ! http://www.ezflaphandle.com
EZFlap
EZFlap's Photo gallery
Postby RobinClay » Fri Jun 17, 2011 2:03 pm
I don't know where you got this from, but....
It is no less impressive for the very poor research:-
London to Tunis is 1132 miles
http://www.wolframalpha.com/input/?i=London+to+Tunis
The plane landed some "two and a half hours after being hit", but didn't come straight home - it still did its bombing run.
Never mind - say two and a half hours flying time - for say 1100 miles = 440 m.p.h.
From http://en.wikipedia.org/wiki/B-17_Flying_Fortress
Maximum speed: 287 mph (249 kn, 462 km/h)
Cruise speed: 182 mph (158 kn, 293 km/h)
Hmmmm... some Bird !
From http://en.wikipedia.org/wiki/File:B-17-battle-casualty1.gif)
her home base was actually in Biskra, Tunisia, so references to "England" and "the Channel" are fiction.
Pity, that - it casts undeserved doubt on the whole story.
RobinClay
Postby kevbert » Fri Jun 17, 2011 10:56 pm
The above story is a complete fabrication. In my younger days I was quite avid in studying the planes and air battles of WWII. I remember that picture well, as it is one of the more famous pictures of the B-17. As I recall, the plane was based somewhere in North Africa, dropped its bomb load on Rommel's forces, then collided with an ME-109 on the return trip. The B-17s were so heavily armed that one of the few effective ways to attack them was head on, that way the enemy fighter was only exposed to the bomber's guns for an instant. This particular ME109 got shot up on its attack run, then collided with the tail of the bomber.
Jeers to the dolt that made up that story, and thanks RobinClay for spotting the flaws.
kevbert
kevbert's Photo gallery
Postby RobinClay » Sat Jun 18, 2011 2:34 am
[Sigh] You have gone W A Y over the top, there - even *you* recognise that the story is NOT a "complete fabrication", it is true in the essential detail.
It's just a pity that someone chose to elaborate without checking....
Yeah - a jerk.
But the true story is still good.
RobinClay
Postby kevbert » Sat Jun 18, 2011 8:59 am
I searched the internets, and found a pilot interview for this bomber. This story seems believable to me.
http://usmilnet.com/smf/index.php?topic=11523.0
And, if you like looking at the amount of punishment that a Fortress can take, here's numerous photos of battle damaged B-17s.
http://www.daveswarbirds.com/b-17/
kevbert
Postby RobinClay » Sat Jun 18, 2011 4:00 pm
Thank you, KevBert, for those links.
Biskra, the base of the "All American", is actually in Algeria, and is about 290 miles from Tunis -
about an hour and a half's flying time at 200 mph
RobinClay
Return to Accident Analysis
