ADS-B Out Mandate - GPS Receiver
Discuss the legality of flying the backcountry, FARs, advocacy, and aviation relevant legislation. Please post other non-aviation related legislative or political topics in Off Topic or Hot Air. Registered users only.
Postby soyAnarchisto » Mon May 21, 2012 2:26 pm
Although they have still not releasesd pricing, there is at least 1 company who has achieved a TSO'd GPS receiver which would plug into the standard 9-pin DSUB NMEA connection to the garmin or avidyne mode s transponders:
http://www.accord-technology.com/nexnav_mini.html
There are non TSO varaints of the same thing in the $200 range from Dynon for the skyview system (small combined waas-enabled gps receiver and antenna that will wire in to the transponder through std nmea ports). It is still unclear (at least to me) if that would be acceptable for an EAB - it seems clear that you would not be able to shoot precision gps approaches without TSO - but general ADSB?
I hope we will not *have* to buy a full GNS430 or 530 TSO GPS to comply w/ the ADS-B out mandate. But I guess we will see in the coming years how much this truly will cost us.
'Greg
soyAnarchisto
FindMeSpot URL: http://share.findmespot.com/shared/face ... gIq9YWI57t
soyAnarchisto's Photo gallery
Re: ADS-B Out Mandate - GPS Receiver
Postby Karmutzen » Wed May 23, 2012 6:23 am
I thought Garmin has finished production of the old 430 and 530 and they are no longer available. I'm about to buy a new transponder, so if ADSB is mandated (not just Alaska/Capstone?), should I be considering only a Mode S?
1973 7GCBC 8.50x6
Karmutzen
FindMeSpot URL: http://share.findmespot.com/shared/face ... LS6rdx7Iz4
Karmutzen's Photo gallery
Postby porterjet » Wed May 23, 2012 7:47 am
Karmutzen wrote:I thought Garmin has finished production of the old 430 and 530 and they are no longer available. I'm about to buy a new transponder, so if ADSB is mandated (not just Alaska/Capstone?), should I be considering only a Mode S?
My original understanding was a mode S transponder would be required to handle the ADS-B signal. However, the more I read about it the less I understand. It appears the "out" mandate might be handled by a stand alone GPS derived position re-transmitter, so to speak. In it's wisdom the FAA is saying carrying a transponder is still going to be required in some airspace even with ADS-B out. But we have until 2020 to figure it out.
John in Saudi
G2 (stol)
porterjet
Postby porterjet » Wed May 23, 2012 8:01 am
John in Saudi
G2 (stol)
porterjet
Postby dogpilot » Wed May 23, 2012 7:04 pm
The FAA will be slow to implement ADS-B, due to budget issues. If you have to consider a new transponder, you may wat to go for the mode S. Homeland security is quietly pushing for every aircraft to have one to uniquely I'd each aircraft. So get the mode S so you don't have to it again real soon.
dogpilot
FindMeSpot URL: http://share.findmespot.com/shared/face ... NmShzCx0dq
dogpilot's Photo gallery
Return to Aviation Regulation and Law
